fdsa487
- El Cajon, a.k.a. The Box
TNT stiffeners.
When they are being welded do you think that they should be welded ALL THE WAY around the whole stiffiner or do you think that a 6 inch bead on then 6 inches off then 6 inch bead on will be sufficient? A welder that I talked to said this would be sufficient but I wanted to make sure.
