Old January 7th, 2020, 16:27
Skeeter Skeeter is offline
Option for engine swap 2000 XJ
Hey yall I'm new to this forum so I may not be in the right place to ask this question but I got a 2000 XJ 4.0L 4x4 with 300k miles and instead of doing a rebuild I'm wanting to drop a new motor in but I dont want to put in another 4.0L (even though it's a great motor) it has the AW4 trans, not sure about T-case. I would like to stay away from the LS swaps due to costing an arm and a leg.
So what other choices do I have with minor frame/body fab?
Any and all info would help.
Old January 7th, 2020, 17:32
jsparhwk jsparhwk is offline
I’ve always wanted to do a diesel swap... but haven’t yet, is that even on your radar?
Old January 7th, 2020, 17:37
Re: Option for engine swap 2000 XJ
Yeah that was on my radar for a while going back and forth with the 4BT cummins or the OM617 Mercedes but both seemed to be out of my ballpark at about $14k when I'm looking more towards $10k or less depending on the donor.
At the moment I've been looking into the Chevy 350, 305, or the 4.7 Chrysler/GM, or the ford 5.0 but I just dont know where to find adapters and or what all needs to be pulled from a donor or bought.
Old January 7th, 2020, 17:43
HotBox HotBox is offline
How about a 5.2 or 5.9 magnum swap. Easy to find and both were available in Jeeps. I've seen some threads of plopping them in an XJ so its definitely do able
Old January 7th, 2020, 17:46
I have not looked into the 5.2 or the 5.9 Magnum. I have seen those threads as well but I have not looked into them as of yet.
Old January 7th, 2020, 19:02
bajabronco bajabronco is offline
How about a 4.7 stroker? It's not a 4.0 anymore :P and you get a lot more power and torque without having to change a ton of things out, like a V8 swap. I just grabbed some good stroker #'s and you are looking at around 290hp @ 5100rpm, 340lbft @ 3700rpm, That is about the same as 5.9L Grand Cherokee numbers which are 245 hp @ 4,000 rpm 345 lb-ft @ 3,200 rpm and it is a new engine as well. Just something to think about. The stroker is a bolt in. Of course if you can find a cheap wrecked 5.9 and have good fab skills, that could be a fun project. Don't underestimate the hidden cost for a complete engine swap though. All the little things tend to add up quickly!
I can only comment on the 5.9 as I had one in my Grand Cherokee. Absolute beast. Anyone who's owned one or driven one can confirm. Would definitely be cool and one of a kind. Simple enough to drop the whole drivetrain in and around me they're found for a grand or less for everything
Old January 7th, 2020, 19:22
Here is the thread on the 5.9 swap in an XJ - https://www.naxja.org/forum/showthread.php?t=1125381
Old January 7th, 2020, 20:53
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
LS truck motor.
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old January 8th, 2020, 07:57
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
Just about any swap is going to cost a good amount. Issue with all the swaps is cooling challenges. TDI conversion is a good diesel option if you haven't looked into. I'd vote against a 4.7 swap. Yes, I have one in my WJ and love it but it's a love hate relationship with that thing. Was just rebuilt and not even 10k it either threw a rockers arm or dropped a valve seat. Still trying to get that figured out. 350 is going to be the best V8 option.
88 MJ, 4.0, 4wd, 3 pedals, Shortbed.
Mods; ACOS, quick discos, HD tie rod and a bitchin air fresher
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
Old January 8th, 2020, 08:50
Check out the sloppy mechanics group on Facebook. Its the home of low budget LS swaps. Truck motors can be cheap, often in a donor vehicle so you've got all the parts.
John V.
RRC VP
Old January 8th, 2020, 09:23
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Yeah LS swap is about as cheap and easy as it gets. Pretty much any other swap is going to involve a lot more custom, or harder to find parts, or leave you with something that is a serious downgrade from the 4.0.
Old January 8th, 2020, 16:18
clydefrog's Avatar
clydefrog clydefrog is offline
LS Swap will be in the $10k range for it to be reliable or a DD, plus or minus a couple thousand depending on your emissions laws and what your Jeep already has (ei: i needed to long arm mine to fit the cats for the swap, you may not have to in your state...just an example of cost variations).
I know you said no LS swap but then you said your budget was $10k to $14k.......LS swap would be the easiest and most economical.
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old January 30th, 2020, 10:39
5.9longarmXJ's Avatar
5.9longarmXJ 5.9longarmXJ is online now
5.2 or 5.9 in my opinion is easiest and cheapest
Fuel pump requires no change and fittings are identical
Stock gauges are retained and computer will talk to them as long as it is the same bus “CCD”
Wiring is 95% the same. When I custom built my own harness using the 5.9 and my 4.0 harness, most of the colors matched.
If anyone is serious about the swap, I am more than willing to provide help
Old January 30th, 2020, 10:46
Transmission options are 44re or 46re for auto. Manuals would be either nv3500 or ax15. The np231 transfer case will bolt right up to any of these. No adapter required
Downside is by today’s standards, power output is low
5.2 230 hp 295 ft/lbs ish
5.9 245 hp 335 ft/lbs.
both will burn gas too. I get about 13-14 mpg in mine.
2000 XJ engine swap options? blistovmhz Modified Tech Discussion 17 October 3rd, 2015 10:01
97 to 2000 engine swap coil packs or distributor. klint96xj OEM Tech Discussion 10 December 1st, 2014 17:55
Engine swap issue in 2000 xj EmpireTiny OEM Tech Discussion 8 April 29th, 2014 09:01
2000 to 99 engine swap question paff336 OEM Tech Discussion 3 June 27th, 2013 13:49
Engine Swap 98 grand into my 2000 XJ? sjroocos OEM Tech Discussion 14 November 9th, 2012 08:07
