Old April 13th, 2016, 13:59
rwat96 rwat96 is offline
Battery Wiring Upgrade
Hey guys, new to the forum here (:
Anyways I am wanting to upgrade the ground wiring and the wiring from the alternator to the battery, but I have not been able to find clear information on what to do with the charging wires to the alt? I have a mild audio system in my jeep (about 600w rms total) and it causes dimming when cranked and I plan to upgrade my headlights and install some aux lighting in the future. Also i should note i just recently upgraded to a 136 amp grand cherokee alternator as well because my stereo killed my other alternator. Any suggestions or pages covering this would appriciated.
Old April 13th, 2016, 14:59
jackmb jackmb is offline
Re: Battery Wiring Upgrade
I finally got around to installing new cables on my XJ from Kelleyswip.com. Quality.
Old April 13th, 2016, 15:42
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
Sierra Chapter Treasurer
Dimming headlights has more to do with voltage drop. I used to have the same problem. I'm still running the same stock alternator and the dimming is no more. The combination of upgrades I made was to install better power cable to the amp(2 guage for a 500 watt amp), I picked up a better battery, refreshed all my grounds, and upgraded my headlight harness. Dimming has disappeared. I'm running stock alternator and battery cabling as well. Just went through and cleaned all the major ground and positive contact points.
The major point is to make sure your supplying your amp with quality cable. Not all cable that is label a certain size is actually that size. In my recent fridge install in my van I found the power cable that had previously been installed was closer to 10 gauge than the 4 gauge it was labeled as.
Sent from my iPad using Tapatalk
Old April 13th, 2016, 16:41
iluv83vettes's Avatar
iluv83vettes iluv83vettes is offline
When did you order them?
Old April 13th, 2016, 21:02
Anak's Avatar
Anak Anak is offline
Stranger
Here is a link to most of what I did on the battery front: http://www.naxja.org/forum/showthread.php?t=1108471
Baby it's cold outside.
Old April 14th, 2016, 07:16
Ya I knew a higher amperage alternator would not fix the dimming, I just did it because the extra power wouldn't hurt, especially with wiring upgrades. And the wiring to my Amps is adiquate and actually the Guage it's suppost to be. I am running 8awg to my speaker amp nd 4awg to my sub amp. So the problem lies in the stock ground wiring, and I want to upgrade the charging wires too while j am in there as they are wimpy as well .
Old April 14th, 2016, 07:18
Those picutres are really helpful and they answered a question I had about wiring to the PCM. (:
Old April 14th, 2016, 08:07
trippled trippled is offline
I ran 4gauge off the alternator thru an audio type enclosed inline fuse holder (pick your amperage), then connected to the the positive post of the battery. Has worked great for years now and was cheap to do.
Old April 14th, 2016, 08:54
Don't you have to run the wire to the PCM first though or you won't be able to run the car off the alternator if the battery goes bad? Or did you do thaf?
Old April 14th, 2016, 11:41
No. The factory one just goes thru the fuse box. I didn't do anything with the field wires, which go to the pcm.
Old April 14th, 2016, 11:46
Ah ok thankyou!
Old April 14th, 2016, 11:48
DeftwillP's Avatar
DeftwillP DeftwillP is offline
I thought the same. Anybody heard from Jon?
Old May 6th, 2016, 19:35
XJwonders XJwonders is online now
Huh, what?
I make battery cables if anyone is interested. Been selling them over at CherokeeForum for s while.
Old May 6th, 2016, 19:58
What is your pricing/options?
Old May 6th, 2016, 20:22
Huh, what?
http://www.cherokeeforum.com/f73/upg...cables-221513/
Pretty much in a nutshell, 4 awg kits are $125 shipped, that's including the fuse holder and two 150 amp fuses, and positive/negative military style terminals.
The 2 awg kits are the same except in thickness and go for $160 shipped.
Battery wiring upgrade Brad Klammer Modified Tech Discussion 22 June 23rd, 2017 18:47
Battery cables upgrade Dest OEM Tech Discussion 20 April 5th, 2010 16:27
Wiring upgrade (starter to battery) Ba-Riedo Modified Tech Discussion 7 November 26th, 2008 14:26
Battery Cable Upgrade? MyJeepXJ OEM Tech Discussion 4 September 17th, 2006 11:02
battery wiring upgrade Devil_Mutt OEM Tech Discussion 6 April 18th, 2006 20:28
