- Torrance, CA
Okay, so here's the deal. I've got a line on getting the trailer below for a good price, but I want to see what you all think it's worth.
It's a 1983 Burro trailer. The cabin is approximatly 10' long. The total trailer height is about 8'. I am taking it for granted that I'll have to to somewhat major interior work (it's been sitting awhile in a moist enviroment).
I haven't seen the inside, but I think it has a range and possibly a 'fridge (it has a 7 gallon propane tank on the front of it).
It has trailer brakes, I don't know anything about the function of them, I don't think this trailer has moved in maybe two years (registration expired some time in 2002).
The outside has some mold on it, that is what the dark stuff is. The plastic shell appears to be intact though, and from the look of it will easily clean up. The only wildcards on the outside is that cover for the seam up top (the dark line going through the center) which I'd like to replace and that rooftop vent, I'd like to get something that is more of a flush mount, plus it appears to be aftermarket and I'm not sure it seals water well, I'd be replacing it no matter what.
If I do get it I might just replace the axle with another more conventional axle (it has some odd swing arm spring I think, either that or it's un-spring) with leaves, so I can bring it up a few inches, the rear bumper is a mere 9" off the ground.
Anyway, here are pictures of the outside...
Thanks,
Sequoia
Thanks,
Sequoia
