Old March 13th, 2006, 12:50
2000XJSPORT's Avatar
2000XJSPORT 2000XJSPORT is offline
Re: Extended Idle 97-01 Install
So I guess I will switch them and see what happens. I will flip the orange and the black and then try it. The switch works the way it is now so if this does not work I will go back to the way I have it now. Sound ok?
thanks for the help too.
Alex
Old March 13th, 2006, 13:18
langer1's Avatar
langer1 langer1 is offline
Alex
The fog light power goes off when the high beam are on so that's your other problem.
The (run) ign wire should power the High Idle circut not the fog light power.
Old March 13th, 2006, 13:41
Ok thanks. I will switch the wire and see if this fixes the problems. Thanks again.
Alex
Old March 13th, 2006, 14:45
Problem fixed. I had the wires wrong in the plug and I also did connect the Ign (Run) wire. The Ext Idle switch lights up and works great. Thanks again langer1 and JEEPZZ for all your help.
Alex
Old March 13th, 2006, 17:25
langer1's Avatar
Great
Old March 13th, 2006, 20:18
TacticalFats TacticalFats is offline
That's looks great.
I have grounded the same wire, but I use a ghetto toggle up on the black spot to the right of the intrument cluser. It's right under the ghetto toggle for the aux fan, and above the ghetto red momentary switch for the air horn.
Old March 14th, 2006, 07:10
JEEPZZ's Avatar
JEEPZZ JEEPZZ is offline
Alex
That's great! Does your illumination still work correctly too?
Looks like I'll have to go and reroute mine.
Old March 14th, 2006, 14:42
JEEPZZ,
Yeah it works great. With all 4 wires hooked up, it lights up and turns on.
Alex
Old March 17th, 2006, 17:23
CommandoXJ96's Avatar
CommandoXJ96 CommandoXJ96 is offline
alright... i know this says 97-01 install, but I think this would be the best place to ask this. On PCM 12 on the 1996 XJ the wire run through is a dark blue wire with an orange stripe, but it does the same thing supposedly (according to other threads it should be that color even and it is afterall pcm12).
So i disconnected my battery, disconnected the large harness and spliced into the blue and orange PCM12 wire. I extended the wire out (good connection I am sure of...) reattached the harness, the battery and started her up. then i grounded the wire... nothing. tried grounding and then starting... regular idle rpm. i disconnected the battery etc and redid the connection and tried everything again... No results again.
the only result i did notice is that now my check engine light is on - Code 23. Code 23 is the intake manifold temperature sensor giving too much voltage. I think this may be just becuase i moved the iac sensor to the air box (a long time ago), and I've seen this code show up before and go away by itself when i had originally moved the sensor.
I have no clue what I did wrong, but im not sure what else i can do now - other then ask you guys for some help. i sure could use it.
Old March 17th, 2006, 17:54
langer1's Avatar
I don't know if you have the correct wire but it needs 12+ not ground for high idle.
The ground on the switch is only for the light.
Find Power Steerling sens grounding that wire should give you high idle.
Just be carefull if you get the wrong wire you will blow the ECU.
The wire should be DK Blu-Wht or Violet.
Old March 17th, 2006, 18:35
well, i misread earlier then, i was under the impression the ground was what needed to complete the curcuit. i attempted connecting the wire to the battery 12v+ and still got no response. still have code 23 and the CEL. dang... thx for filling me in on the positive though. dont know what to do about this now...
Old March 17th, 2006, 19:00
langer1's Avatar
That was for the 2000 yours is totaly different.
Like I said it looks like like your can ground the PS SW input on yours.
Old March 17th, 2006, 22:22
i guess ill look into it more tommorow when i have some time and just put it back how it was.
Old March 18th, 2006, 08:05
well... from looks of this post it should be the same except for the dashboard pieces. should be the blue-orange wire in pcm 12 for my 96, and again "should" serve the same purpose.
Originally Posted by JEEPZZ
Here's some info regarding the computer wire connection to be used for the extended idle setup:
EXTENDED IDLE SWITCH TEST
OPTIONAL POLICE PACKAGE ONLY
The extended idle switch is used to raise engine idle speed to approximately 1000 rpm when the auto shifter is in either Park or Neutral position. A rocker-type switch (extended idle switch) is mounted to instrument panel. This switch is available only with 4.0L engine when supplied with optional police package.
The extended idle switch will control a ground circuit going to the powertrain control module (PCM) When a ground signal (through the switch) has been received at pin/cavity A-12 (circuit K78) of the PCM, engine idle speed will increase.
For 1984-1992 I6 XJs and all I4 XJs:
Not an option in computer pin-out.
For 1993-1995 I6 XJs:
PCM Pin # 10, Purple, [60-pin connector] (Switch On: 1V, Off:12V)
For 1996 I6 XJs:
PCM Pin # 12, dark blue/orange, [Black "A" 32-pin connector] (Switch On: 1V, Off:12V)
For 1997-2000 I6 XJs:
PCM Pin # 12, gray, [Black "A" 32-pin connector] (Switch On: 1V, Off:12V)
Switch location for 97+ (optional 4 opening switch bezel)
Old March 18th, 2006, 10:01
jeepinarkansas's Avatar
jeepinarkansas jeepinarkansas is offline
Why would one want this option?
Extended Idle Switch??? RTicUL8 OEM Tech Discussion 49 March 24th, 2009 03:41
Extended Idle??? pa_muddin_xj OEM Tech Discussion 6 June 10th, 2005 21:54
Extended Idle??? Gridlin Jeep Street and Performance 1 March 23rd, 2005 08:40
WTB: Driver side vent, overhead console, and an extended idle switch bezel 90Pioneer Wanted: Private Party Only 1 January 30th, 2005 13:54
WTB: Factory Extended Idle switch bezel for pre 97 XJ 90Pioneer Wanted: Private Party Only 5 October 3rd, 2004 17:27
