Old October 24th, 2010, 00:28
90Pioneer 90Pioneer is offline
Trying to remove the cross shaft in my 8.25 to pull a shaft but it hits the ring gear
Sorry for the second thread but the other one was filled with removing the cross pin retaining bolt. Got that accomplished but now I have a whole new problem.
Chrysler 8.25, LSD w/ 4.56 gears. Removed the cross shaft retaining pin. Gently tried pounding out the cross shaft however I could only get it 3/4 of an inch out until the edge of it hit the ring gear.
What in the world do I do now??? All this to find out if I have a 29 spline shaft or not.
Here's a pic:
I do not need this axle. It's bent badly, and I will be replacing it. The only thing I will be keeping are the gears and the LSD to have a shop swap into a new axle. But I need to get one with matching spine shafts or the LSD wont work.
Could I cheat and sawzall one of the tubes in half? Do the splines run all the way down the shaft or just at the end that goes into the housing?
Old October 24th, 2010, 03:22
ColoradoRaptor's Avatar
ColoradoRaptor ColoradoRaptor is offline
Headbanging Hillbilly
Re: Trying to remove the cross shaft in my 8.25 to pull a shaft but it hits the ring
You are going to have to grind the gear tooth to get it out. If you take your time and remove only what is needed to get the pin out you will be fine.
People crushed by law, have no hopes but from power. If laws are their enemies, they will be enemies to laws; and those who have much to hope and nothing to lose, will always be dangerous. Edmund Burke
Old October 24th, 2010, 04:41
jbsjunk's Avatar
jbsjunk jbsjunk is offline
Turn the pin as you pull it out. There should be flats ground in it to get it past the ring gear. Or try going the other direction and see if that helps.
Old October 24th, 2010, 04:49
mcantar18c mcantar18c is offline
Its been established in his other thread that his pin has no flat/ground spots.
Old October 24th, 2010, 05:07
jbsjunk's Avatar
How did the pin get in there then, magic? If there was a link to the other thread it would've been known if the shaft was ground or not.
Grind the ring gear a fuzz then.
Old October 24th, 2010, 05:11
Link to the other thread is 3 down from this one in Mod Tech
Old October 24th, 2010, 05:13
Quick question Pioneer, what year heep did that axle come out of?
Old October 24th, 2010, 06:48
RCP Phx RCP Phx is online now
x2,chech the other side of the carrier to see if they ground the teeth down on that side.
Old October 24th, 2010, 09:19
bosco01xj's Avatar
bosco01xj bosco01xj is offline
Why don't you just remove the ring dear from the carrier?
Old October 24th, 2010, 09:33
ChiXJeff's Avatar
ChiXJeff ChiXJeff is offline
Curmudgeon
Think about that one for a second.... the ring gear has nowhere to go. It can't go left past the carrier, and the pinion gear is preventing it from going to the right.
The cross shaft went in somehow, it'll have to come back out the same way.
ChiXJeff
Lifetime member
"Jeeps are Cherokees. All other models are wannabes." Deb. K.
Old October 24th, 2010, 10:03
mcdavid123 mcdavid123 is offline
Looking at the spider gear picture on his LSD thread, it looks like there is a flat spot at the center of the cross pin, not the ends (Post 14). What about rotating the crosspin so that the flat is facing an axle shaft, then push the shaft in, dropping the C-clip. Then do the same for the other side. I'll bet the cross pin was installed before the ring gear was put on.
Old October 24th, 2010, 10:46
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
SOMEONE is thinking here!
That did not occur to me when I made my suggestions at ~3AM last night.
Give that a try, I bet it works.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old October 24th, 2010, 13:43
bosco01xj's Avatar
so... take apart the axle.
and yeah... it did get in there somehow. i bet it got installed before the ring gear was put on. so... take it out the same way.
Old October 24th, 2010, 13:44
ECKSJAY's Avatar
ECKSJAY ECKSJAY is offline
Water is dirty
derp
Old October 24th, 2010, 16:04
johnnyc's Avatar
johnnyc johnnyc is offline
The carrier and ring gear have to be installed in the pumpkin BEFORE installing the axle shafts, c-clips, and cross shaft. There is NO way you can install the cross shaft before the ring gear.
Front drive shaft hits exhaust flange 01whiteXJ Modified Tech Discussion 8 January 21st, 2010 20:07
Long shaft or short shaft speedo gear? jeeperguy21 OEM Tech Discussion 3 July 23rd, 2009 16:54
D35 cross shaft RenegadeStang OEM Tech Discussion 8 July 5th, 2008 10:02
8.25 Cross Shaft Lowrange2 OEM Tech Discussion 18 November 18th, 2007 22:33
Front drive shaft hits exhaust dodgetk81 Modified Tech Discussion 16 April 11th, 2005 05:07
