Old July 15th, 2019, 19:38
Pgw1995 Pgw1995 is offline
2000 intake manifold
I have a 91 4.0 in my xj. I also have a blowed up 2000 Grand Cherokee 4.0 setting in the shop. I was wondering if the intake manifold of the 2000 would be an upgrade for my 91. My 2000 is a complete motor, minus block, has a fist size hole in it. Would the 2000 intake have a noticeable difference? Or just stick with the log style?
Old July 15th, 2019, 19:42
Also, like I said, itís a complete motor. How hard would it be to swap over to the electronic ignition? Would it be worth the time?
Old July 16th, 2019, 04:05
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: 2000 intake manifold
Use the ECM and engine control sensors for the model year of your Cherokee ( 1995 ?? ).
The 2000 manifold might give you a few HP if you install other performance mods at the same time.
Originally Posted by bimmerjeeper
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old July 16th, 2019, 08:00
Heavyopp Heavyopp is offline
I have a 98 grand manifold sitting in my spare parts pile -- the power steering mounts on the manifold do not match up to what is on my 96 XJ manifold
Be sure to check that on yours
Old July 16th, 2019, 09:32
Thanks, I actually have a 98 Cherokee with a 91 motor, transmission, and transfer case. 98 TCM and ECU. I recently had to change my transmission to a 2000 because I couldnít get the TCM to read the 91. (Didnít find out this till about 2wks after I bought it, tried to buy a speed sensor, guess what a 98 speed sensor wonít fit a 91 AW4). Donít know how they did the motor but no issues there. Do like the 7120 head though. Just not sure that the 2000 Tupy intake manifold will fit the 91 7120 head. Was just trying to come up with some mods since I have all these spare parts, they are all off a Grand though.
Old July 16th, 2019, 13:25
Jim Malcolm Jim Malcolm is offline
The 2000+ intake will fit the 7120 head just fine. You'll need to change the PS pump bracket and the pump as well, although I believe you can drill out the mounting holes to make it work, but don't quote me on that. Regardless, the improvements to be belt tensioner make the swap worth every penny, cut, swear word, etc. Any performance improvement is purely icing on the cake.
WTB / WTT: 2000+ intake manifold cherokeeproject Red River Chapter For Sale/Wanted 4 March 13th, 2014 09:57
2000 intake manifold CrazyChef110 NAC Classifieds 2 December 11th, 2009 14:46
2000 Intake Manifold: Is it really worth it? xjh3 Jeep Street and Performance 19 May 7th, 2007 12:36
2000 xj intake manifold MATTVW65 For Sale: Private Party Only. XJ ITEMS ONLY 3 March 19th, 2007 14:52
