Old October 9th, 2019, 06:33
Yahooty Yahooty is offline
98 XJ stalls need help diagnosing
I have a 98 XJ with a 4.0, automatic trans and about 170K miles. Several times now the rig has sputtered to a stop while driving. I can put it in neutral and it may keep running, but the rpms drop way down. If I feather the gas pedal the rpms will go up and down a little.
It almost seems like it it not getting fuel. I'm also thinking it could be the catalytic converter maybe too, but seriously, I'm no mechanic.
I nursed it home last night with lots of sputtering, etc. Any ideas?? I'm sorry, but I won't be able to answer right away.
Thanks
Old October 9th, 2019, 07:10
Heavyopp Heavyopp is offline
Re: 98 XJ stalls need help diagnosing
Gotta check your fuel pressure — sounds like a fuel pump giving up
Old October 9th, 2019, 10:08
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
You should start your diagnostics by checking for any saved or pending Check Engine Light trouble codes.
The symptoms should make you suspect the fuel pressure, the Crankshaft Position Sensor, the Idle Air Controller, and the battery. Test each of these, and also visually inspect the wire connections and wires for each. The Cat Converter has a service life of about 150,000 miles, if you suspect it is old, or failing, you should consider replacing it.
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old October 9th, 2019, 17:43
Good advise. I'll check that stuff out.
Diagnosing a Bum 2.5L bad_idea Jeep Comanche MJ (1985 - 1992) 2 September 30th, 2019 09:29
Need Help Diagnosing a Problem 2jeepdrivers OEM Tech Discussion 28 October 4th, 2008 09:37
Help diagnosing a problem. victor_s OEM Tech Discussion 7 April 1st, 2008 21:57
Need some help diagnosing a noise 01_XJ OEM Tech Discussion 17 March 13th, 2007 08:25
Diagnosing help! cyberbackpacker OEM Tech Discussion 3 October 13th, 2004 12:48
