Old September 13th, 2018, 19:25
1manwolfpack's Avatar
1manwolfpack 1manwolfpack is offline
Winch only mount, where to buy
Hi, I'm looking for a winch mount with no bumper. I want to just cut out a section of my stock bumper to install just a winch mount. I'm trying to keep the jeep as light as possible. Does anyone know where to buy one?
I would post pictures, but I haven't figured out how yet.
Old September 13th, 2018, 20:08
freerider15's Avatar
freerider15 freerider15 is online now
Re: Winch only mount, where to buy
Boostwerks hidden winch mount is about as close as you're going to get.
The stock "frame" isn't remotely strong enough by itself.
XJ Buggy On Tons
Old September 13th, 2018, 22:20
I have center and front frame stiffeners. I can fab up mounts, but my time is more limited so I was just trying to buy something to slap on.
Old September 14th, 2018, 07:03
Anak's Avatar
Anak Anak is offline
Stranger
If your time is limited then the Boostwerks mount is probably your quickest path to a well built solution.
The only alternative I can think of is to fabricate mounts to use something like this: https://www.amazon.com/Driver-Recove...ch+mount&psc=1
But then you are back to fabbing up mounts, so you probably ought to just start from scratch and build the right thing to begin with.
Or, go with Boostwerks and support your steering while you are at it.
Baby it's cold outside.
Old September 14th, 2018, 08:46
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Here is a winch tray.
https://shop.harborfreight.com/media...mage_26559.jpg
https://www.harborfreight.com/univer...unt-62446.html
Not at all sure how you plan on mounting it securely, winching puts a tremendous amount of bending stress on the chassis, especially in side pulls.
Show us some photos when you finish the project.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old September 14th, 2018, 19:45
Rick.rob Rick.rob is offline
Wouldn't a front receiver work and have winch on a cradle.
Old September 14th, 2018, 20:25
Greenz's Avatar
Greenz Greenz is offline
One could but...
Pros:
- can be used front and rear
- store it in a dry place when not being used
Cons:
- Still need to beef up the front mount for a receiver
- Heavy to lift winch and cradle combo
- If taking along and not using it, where to store securely?
- Approach/departure angle is lessened when in use
- long run of heavy power source cable if used in rear
Boostwerks winch/steering brace combo is awesome. I have it. It's a lot of work to install but well worth it. There may be limitations to which winch can mount to it though.
Old September 21st, 2018, 20:22
JMOliver's Avatar
JMOliver JMOliver is offline
Old September 21st, 2018, 20:23
JMOliver's Avatar
Here’s mine, I never put bumper back on though!
Old September 24th, 2018, 15:52
LLLux31 LLLux31 is offline
I have the DetourUSA backbone on my Liberty and it works great. I've triple line pulled an F350 quadcab out of a lake with it.
recomondations on winch bumper w/ recessed (lowered) mount for winch? jmg222 Modified Tech Discussion 14 August 6th, 2015 18:35
winch mount-which mount? bcmaxx Modified Tech Discussion 16 December 7th, 2006 08:25
Warn 8K+ winch, XJ rock winch bumper or Warn multi mount Big Red Wanted: Private Party Only 0 June 10th, 2006 20:52
Winch Mount (Have you seen This?) Harvo Modified Tech Discussion 9 December 4th, 2005 21:12
Factory winch mount with aftermarket winch BlackXJ Modified Tech Discussion 18 May 16th, 2003 02:05
