Old January 30th, 2021, 19:19
Evan03 Evan03 is offline
lockers! what ya running and why?
Here's the grizzly link with front gear set.
Be forewarned the locker is likely back orderd I got lucky and mine shipped a couple weeks after I payed for it.
The Detroit locker might be stocked better. I went for grizzly because I pretty much flipped a coin and took the path less traveled
https://www.ronsmachiningservice.net...-usa-gear-pkg/
Old January 31st, 2021, 05:36
RCP Phx RCP Phx is offline
Re: lockers! what ya running and why?
You haven't said what axle it's for but here's a C8.25" .........
https://www.quadratec.com/products/16100_320.htm
Old February 1st, 2021, 07:01
denverd1 denverd1 is offline
Swapping axles. Dana 44s
Old February 1st, 2021, 14:41
jrowell's Avatar
jrowell jrowell is offline
Originally Posted by Anak View Post
I have a locker in the rear, but I don't refer to my rig as "locked" unless the locker is engaged.
If someone tells me they are driving a locked rig I am going to think they mean they are running a spool or a Lincoln (or Miller) locker.
I don't know if the variance is regional or personal, but I do not think it is safe to assume that if you tell someone your rig is "locked" they will understand that it is sometimes locked and sometimes not. More clarification is needed if you actually want people to understand.
Hey, that's a good point... maybe it is regional. I know when I'm leading a large run we'll go down the line of rigs and ask anyone I don't recognize.. "you locked or open"? Typical responses are "ya, locked in the rear" or "I'm open" Maybe it's a slang in my area. I don't need to clarify spooled or welded cause you can pick those rigs out of the line up easily.
Old February 1st, 2021, 16:23
stickandrudder stickandrudder is offline
Originally Posted by srb531 View Post
e- locker front, detroit locker rear, just works. lsd & trutracs are a waste of money. imo, if ur really wheeling it.
I can attest to this. I’m on 35s and it over powers the trutrac when you need it most. Both front and rear get overpowered when I snow wheel and on rocks and it happens a lot. Holding the brake just doesn’t cut it. Currently installing ARBs. The trutracs have been great for icy roads.
Old February 1st, 2021, 17:50
devildog0's Avatar
devildog0 devildog0 is offline
Power Trax no slip in my D30, open rear 8.25. In the past I ran Lock Rights but the No Slip truly is smoother.
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old February 1st, 2021, 18:49
Phil's Avatar
Phil Phil is offline
Originally Posted by denverd1 View Post
ACTUAL QUESTION:
Has anyone run an auto locker (see above) with hydro assist??
I run a front spool with full hydraulic steering, if that is close enough. Sticky 37s, drive flanges.
No issues steering, the ram forces the knuckles over to where you want them.
Spotters lead the way!
My green junk. or #StellaFTH4
1989 XJ Wagoneer. Basically stock.
G & G Offroad and Auto Repair can make you think you can run the Box!
Old February 1st, 2021, 18:50
THANK YOU
Yes close enough, I'd say better
Old February 1st, 2021, 18:51
Phil's Avatar
Originally Posted by Evan03 View Post
Climbed over some vertical rocks at slow slow crawl that I could do before but had to finagle around and hit the perfect line with alittle umfff because the front didn't want to pull it self up. The welded rear would walk sideways.
That pushing/walking is why the selectable locker goes in the back, if you have one.
Old February 1st, 2021, 18:56
Interesting.
Old February 1st, 2021, 20:24
True. All gone.
If money was a concern I'd leave rear open and run a grizzly or Detroit in the front.
Sometimes the walking sideways is good it finds better lines then I pick
Old February 1st, 2021, 22:05
SlowXj SlowXj is offline
True. All gone.
Driving by brail!
Old February 2nd, 2021, 01:59
tm8chris tm8chris is offline
I'm using Power Trax no-slip also, and have no issues whatsoever.
Old February 2nd, 2021, 07:26
Two walking is better than two digging going no where.
Here's grizzly on jack stands
https://youtu.be/3jsrosNd7uE
Old February 2nd, 2021, 08:34
Can't imagine running no rear locker. lift a tire and you're basically stuck, no?
Time for 2ea: Lockers, gears, master kits, lube lockers and Shipping - 1019$ RWKHausSupply Vendor's Specials 5 November 26th, 2012 08:18
Will not stay running (not normal running issue) bigbadwolf54 OEM Tech Discussion 5 August 26th, 2007 14:07
what lockers you guys running up here in northwest? 93xj-jeeper NorthWest Chapter 11 April 28th, 2005 13:44
Calling all guys that are running OX lockers. hjeepxj Modified Tech Discussion 19 November 11th, 2004 17:19
