Old November 18th, 2019, 06:12
Rockdrummer93 Rockdrummer93 is offline
My XJ's Big Boy Stage II
So new shock tabs are in. Waiting on bumpstop parts to come in to get those installed. Iíll try and get those done sometime this week the hopefully get the Jeep back to my house by the weekend.
Old November 18th, 2019, 07:26
Evan03 Evan03 is offline
Re: My XJ's Big Boy Stage II
Thanks for the updates
Always look ford to seeing what your up to.
Old December 8th, 2019, 19:07
I got the Jeep home last weekend after getting back from Chicago for thanksgiving. Got it on jack stands and dropped the front end out. Yesterday morning I got it sitting on its own weight again. Need to pre load the driver side a little more for my weight when I am in the driver seat but other than that the front is good. Now before I take it out again. I need to drop the rear out and tighten all the jam nuts. With the IronMan4x4 crossmembers set up the way it is I have no room to tighten the lower control arm jam nuts at the frame. Then will through something in for bump stops and should be ready to ride. As for the front bumpstops I am planning on getting airbumps so for the time being I decided to set up for those but run an old school poly bumpstop in its place. That why I wasnít cutting anything off when I actually got air bumps.
Old December 18th, 2019, 07:50
Keep the photos and progress comming.
Coolest build going on the site
Old December 18th, 2019, 09:10
Thanks man will do!
Old December 18th, 2019, 09:13
Got some rear bumpstops on this past weekend. I used the factory location but with the axle being pushed back Iíll have to build a little plate off my truss. This will also help dial in the stop.
Old December 18th, 2019, 16:02
Looks great.
Are you running 7/8 heims or 1.25?
Old December 18th, 2019, 16:05
Looks great.
7/8s uppers 1.25s lower
Old December 18th, 2019, 16:12
Sweet.
I did a track bar on my Cummins and 7/8" is holding up so far. about 30k on them
Old December 23rd, 2019, 10:00
POSrenix's Avatar
POSrenix POSrenix is offline
Pics?
Old December 23rd, 2019, 10:47
Originally Posted by POSrenix View Post
Pics?
What you looking for pics of? I can what ever later today
Old March 24th, 2020, 04:19
Alright so have got a decent amount done since my last post. Rear bumps are completely done and tuned in. Need to readjust my limit straps front and rear. Put in some new headlights. Setting it up for some more tube work later on. Found out the clicking I was hearing at Harlan last time I went was the front CV joint being wore out. Rebuilt that and then took it out to gulches the other weekend. As soon as it flexed out it started clicking again so need to do something else with the front driveshaft. Iím maxing it out and binding it up. Probably gonna order a 1410 single joint builder kit and go that route. Will be the cheapest joint set up to get the angles I need. Other than that Jeep did really good on the trail!
Old April 14th, 2020, 11:03
sh!nny sh!nny is offline
this is awesome
Old April 15th, 2020, 11:46
upsidedownxj upsidedownxj is offline
Originally Posted by sh!nny View Post
this is awesome
x2
Old April 20th, 2020, 02:13
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
What a monster!!! Can’t wait to half the stuff you got for n there, same red as my oil guy; truly my heels idol! LOL
But ah... Where’s the drag link? :?
Full hydro would delete it, but hydro assist still needs one... I must be missing something
97í XJ lift lockers 35s mid arms 9"/hp30 trussed warn hubs wj brakes 1ton OTK 4.56s etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Hello everyone! also, Old Stage?... Peach95 Colorado Chapter 9 May 7th, 2015 06:47
Stage 8s not doing their job XJLI Modified Tech Discussion 4 May 27th, 2013 17:59
Old stage again. 4-28 in4aride Colorado Staging Area 52 April 28th, 2012 16:56
xj stage 2 emr1101 Modified Tech Discussion 15 July 20th, 2008 21:39
Jet Stage 2 jcamp1221 For Sale: Private Party Only. XJ ITEMS ONLY 7 April 2nd, 2005 17:11
