Old May 10th, 2018, 10:24
RCP Phx RCP Phx is offline
Switching to AN fitting for auto trans
Looking to go to braided SS and wondering what everybody is doing for the "quick-coupler" tube end on the radiator?
Old May 10th, 2018, 22:31
Heavyopp Heavyopp is offline
Re: Switching to AN fitting for auto trans
You mean this?
Old May 10th, 2018, 22:52
the_weirdo's Avatar
the_weirdo the_weirdo is offline
Ugh
Try this thread: https://www.naxja.org/forum/showthread.php?t=1045807
I'm not a complete idiot, some parts are missing.
Old May 10th, 2018, 22:54
Black1990jeep Black1990jeep is offline
For the bottom, after the quick connect is removed, you have a 3/8 inch tube sticking out, with a that ridge formed maybe half an inch or so from the end, there is enough room on the end to fit a compression fitting, again from ACE hardware. so get a compression to pipe thread, male or female to then connect to a pipe to AN adaptor
Old May 11th, 2018, 07:54
Originally Posted by Heavyopp View Post
You mean this?
I'm not sure what that is(3/8" comp), but I'm look for a fitting for the quick disconnect to AN hose.
Old May 11th, 2018, 07:55
Originally Posted by the_weirdo View Post
That was long but I didn't see anything that would help.
Old May 11th, 2018, 08:51
This...
http://www.acehardware.com/product/i...631279.2631284
a 3/8 inch compression fitting with pipe threads on other end. you may choose male or female pipe threads, one linked is male thread. The attach an AN to pipe thread adaptor to it. Check out ACE plumbing fitting section for these. Good luck
Old May 11th, 2018, 09:02
I'm not f***ing with a 800$ radiator.
Old May 11th, 2018, 09:18
Sorry -- thats a 3/8th compression by -6an
not much space down at the bottom fitting on the radiator -- this fitting allowed a painless swap over to -6an
Old May 11th, 2018, 09:28
I have found what I was looking for. I called Griffin yesterday to verify the lower fitting - it is "3/8" SAE Male Quick-dis-connect! I just got off the phone with Holley regarding all the specs. It should work perfectly!
Old May 11th, 2018, 10:29
Weasel's Avatar
Weasel Weasel is offline
Both of my griffens are using a 3/8 saw to An -6 adapter. Push lock hose ends on both sides.
Just add lightness
Old May 11th, 2018, 11:13
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
The stock tube sticking out of the bottom the radiator take a 3/8" transmission cooler oil line just fine and the ridge prevents the fuel injection hose clamp from slipping and coming off.
Years ago, the QD started leaking out in the boonies and this was the fix I came up with at the time and have remained with for the last 15 years, with no leaks or other issues.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old May 11th, 2018, 12:19
Considering my factory quick couplers have been on/off several times in the past 18yrs, I'll take my chance with something meant for the job and better made!
Old May 11th, 2018, 20:37
lazyxj's Avatar
NAXJA Member #1310
I rarely pull the radiator, so it isn't much of an inconvenience .
Once connected, I leave the flex line alone, it's easier to disconnect it upstream.
As to being 'better made', what's to judge, the fitting on the Mopar radiator was designed to have an oil line connected to it and to withstand whatever forces are normally applied to it.
All I have done is to change the hose attachment method to some thing more dependable than the QDs. It certainly isn't less dependable than the OEM QDs.
I'm retired and my budget is limited to things that add actual functionality or dependability.
Old May 12th, 2018, 23:27
I think I got everything ordered that I'll need(except o-ring's/support clamps).
(2) 14 x 1.5 adapters
(2) 60* hose ends
(2) straight hose ends
(1) 90* hose end
(1) Quick-coupler end
(1) Inverted flare adapter
20' SS hose
11" x 11" Hayden plate cooler ( I have one now but with barbed fittings )
Hopefully this will be pretty much "plug - n - play " !
Loose and leaking trans line fitting rmonte4812 OEM Tech Discussion 9 May 30th, 2011 20:26
Trans temp gauge FITTING ParadiseXJ OEM Tech Discussion 9 March 20th, 2008 11:27
Trans line fitting egon OEM Tech Discussion 3 February 21st, 2004 19:54
does downshifting with an auto trans to slow or brake hurt the trans lapaul OEM Tech Discussion 12 February 21st, 2004 09:26
