View Single Post
  #14
Old October 27th, 2018, 10:04
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: Replacing the Fuel Filter (Renix Era)
Ditto, must be "fuel" and "injector" on the hose. Old style fuel only, hose will not handle injector pump pressure.
Should 50 psi or higher rating if the hose lists the operating pressure.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
