View Single Post
  #14
Old October 14th, 2010, 10:33
Talyn Talyn is offline
Re: Barbed fittings for transmission cooler lines?
If you want to go to NPT, this might help. Autometer # 2267 http://www.jegs.com/i/Auto+Meter/105/2267/10002/-1. However, if you want to go to AN fittings you could use Parker 836 push-lok hose and push-lok style fittings. Any manufacture's pushlock/push lock/twist lock fitting will work.
And as ehall said, air hose fittings are not the right size for the metric transmission fitting.
