fishfighter
- Louisiana
Were is everybody buying there shims?I am looking for a place close by in Louisiana.I did check NAPA,but they would have to be shipped across the country.
fishfighter said:They have a post to stay away from Rusty's.I am new to this and don't want to get burned at the start.Thanks
xj_toker said:Try Rustys or Rubicon Express as stated, you can also try pro comp as well. Just make sure you get the right degree. I bought 2 sets when I put my lift on because I wanted to make sure that I wouldnt have to wait for another set in the mail If I ordered the wrong degree. tim
That's a hit-and-miss method, if that's what you want. You really need to measure the angles of the driveshaft, the t-case output and of the pinion yoke to see what size shim you need.fishfighter said:That is why I am first going to try dropping the Tcase.Is that a good idea to see if vibs will drop?
