theoriginalscion
- syracuse,ny
Did a ZJ rear disk conversion 7 months ago. E-brake shoes are worn down on top side but not towards bottom of shoes. I have the brake setup off a 94 Grand. (In 95 the Rear pads are different,got wrong pads first try.) but rotor and e-brake shoes all have same part numbers.
There is no draging of brakes. wheels spin easily off ground and jeep rolls with no resistance. There is also little wear to inside off rotor, its actually kind of rusted over. I have E-brakles adjusted well, Jeep holds well in gear, and on hills.
Its like the shoes keep wanting to work there way up. I ground down some material on shoes and was able to make clearences better. But I can still hear rotor rubbing againt shoes as I spin wheels.
Anyone else had premature E-brake shoe wear with 94 ZJ setup?
