banderso
- Stockbridge, MI
I picked up the internals from a ZJ proportioning valve to swap into my non-ABS '91 XJ. Tonight I pulled the internals from my XJ valve, and comparing the parts and some of the info I've found here has me a bit confused. Hopefully someone can give me a little insight.
First of all, here is a picture of the parts I have. XJ parts are on the left, and ZJ parts on the right. The plungers are different diameters, and the XJ spring appears to be a hair shorter and have a slightly larger wire diameter. Both springs have 7 windings
In this thread OverlandXJ shows pictures of both the XJ and ZJ proportioning valves. Notice that his XJ spring appears to have 8 windings, while the ZJ spring has 7 windings. His ZJ plunger is pink.
So, did I pickup the wrong proportioning valve (I really thought I got a disc/disc ZJ valve)? Did I pull the right parts, but accidentally confuse the springs?
Thanks.
Thanks.
