ZJ disc brake mounting bracket question
indianaXJ said:
hello:
Is there any difference between the ZJ d35/d44 brake mounting brackets and backing plates other than the axle hole size?
thanks
I'm not actually sure if there is a difference except maybe with the abs sensor or an ebrake cable but the 44 plates do bolt up just the same as the 35 ones do. You just have to enlarge the hole.
The D44a (ZJs with the v8s) will have the hole a little bigger already compared to the d35c. That's about it.
If you can pick and choose between the d35c or the d44a ones, get the d44a so you wont have to grind as much :)
