Ted Z said:My rear R&P has 40 feet on it right now and i'm leaving tommorrow morning.......
You guy's with new gears just need to stop once after you get them hot and let them cool down. Then have at it, you'll be fine.
mark
orgs mfg
Jes said:You guys who are having problems getting your junk ready in time should blame for springing this event on everybody at the last minute.
Jes
EricT said:then it is time to start packing as I leave saturday morning.
Good luck!!!DeadEyeJ said:PROGRESS?!?!?!
Sheesh, I'm just starting!
Let's see now, what is there left to do....
- Install a front axle housing. (!)
- Switch front axleshaft to remove disco.
- Cover the hole in the housing for the disco unit.
- Install rear locker.
- Switch sides of rear brake backing plates (long story).
- Replace rear wheel bearings and seals (have to be pressed!).
- Relocate rear axle 3/4" forward.
- Make some rear lift springs from comanche leaf packs.
- Obtain and install longer e brake cables.
- Modify drag link to eliminate binding.
- Trim fenders.
- Install swampers on new wheels (when they arrive).
- Have Dr. Sawzall ensure that those new meats actually fit!
- Install front tow hooks.
- Go to school full time.
- Work 3 eight hour shifts.
- Sleep...... (yeah, right.)
Yep, this all needs to be done by Thursday morning. Currently, it's 3:05 am Sunday and counting.
Hope I make it. Pray for me....
Jared :wow:
do you have a block off kit, (seal, plate, gasket, axle shaft) ? I've got a kit if you need one, also need help with the locker, what kind of locker / axle?DeadEyeJ said:PROGRESS?!?!?!
Jared :wow:
