i know that there are a few people that have done this...
if you use stock yj front leafs in the front of an xj in a spring-over configuration how much lift (compared to xj stock) will be gained? what if you use the higher rate rear yj leafs?
i'm thinking about using the lower control arm mount for the rear spring eye and J-shackles on the front.
