jabbathewhats
- Sacramento, CA
Can't wait to see where this goes. Looking good!
Sent from my moto g(7) power using Tapatalk
Thanks man!
WB:
Actually, I need to double check WB, with the MJ leaves, the long Ruffstuff perches, and using the most rearward hole on the ruffstuff perches, I think I ended up at 103-104" depending on where I ended up putting my lowers. I try to measure tonight after work and post up.
Coils:
I am using a 6" PAC coil now, but the dude who welded the coil buckets on, welded them pretty high, so its like a 7-7.5" lift because of that. A 6" coil will be fine with the 40s, and I plan to eventually drop it down up front, but I needed the stiffer coil and the taller coils to help not kill shocks and add some On-road stability.
I am using a 12" short body 7100's, I re-valved them to 400/100.
Tires:
These 40s are very true to size, I believe they are 40", I can always measure again but they are huge compared to my old 37s. They are great on road and good enough offroad, I think once they wear in more they will get better. I think the rear traction bar is going to help a ton too. Ill measure tires as they sit now at 22psi which is my highway driving psi.
As for the rear leafs:
MJ bastard packs, with some 4-6" XJ leaves that already on the rig, shackle relocation boxes, and a 1.5" boomerang, I ended up with like 8-8.5" lift, but I haven't put all my gear and my spare tire in it, which adds like 500+ pounds, so I am sure it will be closer to 7.5" loaded.
How far is your track bar from the front coil spring bump stop?
