the search feature is located in the red bar below the vendors ad banner. click on the down arrow next to search and select advanced search. for search terms type rear disk brakes and select modified tech to search in.
With that being said, if you have a Dana 35 the ZJ discs will swap right on.
If you have an 8.25 axle, you will have to open up the center bore on the caliper mounting bracket & maybe drill out the flange bolt pattern (I did) to fit, then mod the ebrake cables to work (easy). Its an easy swap, I did it, I love it, go for it.
