- Houston, Tx
I did mine and it was fine. Parking brake, chock wheels, and put it in drive (engine running). Grinder with cutoff wheel will do the hack real clean as the spinning shaft gives it a lathe effect rather than hacking through the output.
The front ds you're using is out of a slushbox XJ, right? I've heard manual transmission XJs have different driveshafts... might just be the rear. I dunno.
the lengths are different on auto vs manual. and a front shaft from either won't work as a rear shaft in a manual due to the length.
