- Golden, CO
Asking $300.
Came from an '89 with unknown mileage. It has an open carrier and 3.07 gear ratio. Includes parking brake cables, old U-Bolts and plates. You will have to repair or replace the cover; the drain shop makes a nice hole in these.
If you think disc brakes are the shizzznet, I'll keep the backing plates.
If you plan on keeping the drums, the brake shoes have some odd wear. The shoes have "Centric" stamped in the steel. The drums look OK, but I have not had them measured for discard diameter.
Past that, this assembly is relatively clean and dry.
