98hd
- Upper Michigan
'78 f250 d44 front (8-lug). Shortened 3" on the long side, about 65" wms. Rubicon express xj/tj brackets, knuckles rotated. JKS Over Axle bracket for trackbar. Yukon 5.13's and install kit, ARB locker. All new seals and bearings, warn hubs. Dual piston calipers and 1 ton rotors. Has pass knuckle machined for steering arm, and a SKY-manufacturing steering arm for crossover steering, sky draglink, Sky tierod in stock location, all 1 ton TRE's. BTF diff cover, w/ high fill plug.
This axle has about 500 miles on it, mostly w/ the hubs unlocked.
The pass. side brake drags a little, I never used it enough on the road to fix it. I'm about 95% sure it's the hub.
$1500.
Located in Escanaba, MI May help with delivery within a few hundred miles
PICS: http://s57.photobucket.com/albums/g220/98hd/Parts%20for%20sale/
$1500.
