Plays For Jeeps
- Allentown PA
Was installing a swing away on my XJ a few days ago and unsurprisingly The floor of my trunk is gone. I kinda expected that.
But what did catch me off gaurd was the gallon of water wrist deep which had collected there.
It seems as though in that 1 foot of rocker panel behind the rear tires is shaped like a V-Shaped bowl. Water was being kicked up by the rear tires, soaking my rear carpet, and then the water was collecting in this bowl.
I drilled a hole in each body pocket and the water drained right out.
Just thought I would give you guys teh heads up!
See picture for where the water was collecting INSIDE the body panel. To check, pull off the plastic trim pieces (one screw each) the big ones with the cubby hole in them. Then just look down. You may see slushing water.
