WTB rear driveshaft
Colin994
Wellesley Ma
So I ended up ripping the splines off the cut/sleeved front shaft from red jeep I was using, and before I blow the money on a Tom woods I thought I'd see if anyone had one lying around that might work.
weld to weld on the tubing: right around 21"
With the stub shaft fully compressed from the centerline of the ujoint on the yoke to the centerline of the ujoint closest to it on the double cardan: 29"
Happy to get pictures or any other measurements if needed, really hoping to get this sorted before the field and forest season opener so anything that works for the time being would be appreciated.
-Colin
Just grab another stock shaft and make another one ;) Hell, I never balanced that shaft or anything
I'd be all over making a new one if I had a better welder......I really need to invest in one soon I could have all the parts sitting in my garage actually on my jeep if I did
do you even need to cut one down? For 29" compressed looks like a stock manual trans XJ shaft should work?
XJ 87/88 2.5 Automatic 27.950 53003912
XJ 89/93 2.5 Automatic 27.970 53005540
XJ 89/01 2.5 Manual 25.310 53005541
XJ 89/01 4.0 Automatic 30.660 53005542
XJ 89/01 4.0 Manual 29.250 53005543
XJ 89/00 4.0 Manual 27.080 Export 53005544
XJ 89/00 4.0 Automatic 28.620 Export 53005545
XJ 87/88 4.0 Automatic Export 53005260 *
XJ 95/01 Diesel 27.640 Export 52098208
ZJ 1993 4.0 Automatic 30.530 52098341
ZJ 93/95 5.2 Automatic 32.870 w/o CV 53008427
ZJ 94/95 5.2 A500 30.625 w/o CV 52087805
ZJ 94/95 4.0 A500 w/o CV 52098790
ZJ 93/96 4.0 Manual 52098344
ZJ 93/96 4.0, 5.2 31.875 w/ 231, 242 52087805
ZJ 93/95 4.0 Manual 30.000 w/231 52088090
ZJ 93/96 5.2 33.000 w/ 231 53008427
ZJ 96/98 5.2, 5.9 31.250 w/ 249 & Model 30 52098379
ZJ 1996 5.2 Automatic 32.875 w/ 249 & Model 30 52098501
ZJ 96/98 4.0 33.000 w/ 242 52098707
ZJ 96/97 4.0 Automatic 31.250 52098850
ZJ 1996 5.2 Automatic 30.750 w/ 249 & Model 30 52099246
ZJ 96/98 4.0 33.500 w/ 249 52099260
