AZjeepin1
- Glendale, AZ
Now, I know that dieselenthusiast has put one of these together, but I wanted to add to his brilliant idea. After all, it was his writeup that helped me do mine. His original link is here- http://www.naxja.org/forum/showthread.php?t=1085546&highlight=coolant+filter+install
What I found lacking in the previous writeup is a SOLID, no BS parts list (complete with part numbers and costs) and pictures of the assembly prior to install. In my trips to the local stores (NAPA and Ace Hardware) this is the list of parts you will need to put together a coolant filter setup from dieselenthusiast:
1. NAPA/Wix coolant filter spin-on conversion kit (P/N 4019) $55.69
- This kit comes complete with the filter base, 3 mounting bolts, 3 washers, 3 lock washers, 3 nuts, 2 3/8'' steel elbows (only one of which will be used) and a tube of loc-tite
2. NAPA Gold coolant filter (P/N 4071) $17.99
3. (1) 3/8'' hex nipple (Lasco P/N 17-8631 112D) $3.29
4. (1) 3/8'' MIP x 3/8'' MIP brass elbow (Lasco P/N 17-8831 116D) $9.79
5. (1) 3/8'' MIP x 5/8'' brass barb air fitting (Lasco P/N 17-7737 119DG) $5.79
6. (2) 3/8'' inline ball shutoff valves $8.99ea
7. Extra heater hose. The length of this will vary from owner to owner, depending on mounting location.
8. (2) Hose clamps $0.20
Total cost (without extra heater hose and tax)- $110.73
You'll note that the parts list numbers correspond to the red numbers in the pictures.
I hope this helps clear up any gaps in his writeup! Mods, feel free to merge this with the original if need-be.
