1993country
- Danbury
Thank you everyone for all your input. I got more information from my mechanic(Local guy I trust). I am going to try to explain everything as best I can, excuse my lack of proper terminology. The rust is not what is causing the death wobble. My mechanic showed me my bad ball joints, tie rod bushings and axle u-joints/knuckles (causing major clicking/grinding while in 4WD). The rust is on the lower control arm bracket and suspension bracket on the drivers side. He said he can fix the death wobble without replacing the entire front end but he doesn’t know how long the brackets will last before breaking. He is actually trying to save me money, he doesn’t want me to put the money into the death wobble just to have the bracket break off and have to replace it anyway. I did some research (google) and I am pretty sure I can get a bracket and have somebody weld it in place. However, I think it may be cheaper if I find a complete front end with all parts I need, rather than repairing axles, ball joints, tie rod and the brackets. My mechanic said it would be 300 in labor to install the new front end if I find one. I took pictures, I will upload ASAP. Thanks again for everyone’s help.
