Just got finished with an ax15 swap. After everything got bolted back up I took it out for a test drive. It starts and revs in neutral or with the clutch in just fine. Once you get into gear and put load on the motor it just wont accelerate. If you barely put your foot on the pedal it will very slowly accelerate. But if you put anything more than 10% throttle it will just choke and hesitate. Not to mention it runs a bit rougher than usual, it feels like there's too much back pressure in the exhaust, but I'm guessing its probably a vacuum line disconnected. Any Ideas?
