WJ Steering conversion, Distance between tie rod Studs?
garr
Nassau County NY
I'm assisting a buddy in his quest for brakes & steering on his 00 XJ, My truck is parked 165 Miles away from my current location so I can't measure my own truck. I'm roughly dialing in the steering pre-alignment. Using the JKS tie rod & WJ rod ends I need the distance from end to end from the center of the rod end studs.
Thanks in advance.
Why not just measure the rim, front and back? Make sure the front is 1/8"-1/4" narrower than the rear and call it done.
I keep a couple junk rims without tires on them specifically for doing my alignment
Pretty sure that the distance is basically the same as a stock XJ. Minimal difference, if any. Drag link length will be different, but should still not be much.
As stated, though. Spec for a 231 equipped XJ is 1/8 to 1/4", Spec for 242 is 0.
