The 1500 IFS version... And under the 6,000 pound truck I can see them being lousy, but the bearing looks to be the same size as the WJ. And under the lightweight XJ they should be just fine, even on 33s...
And as far as running any kind of a hub kit is concerned, I can't justify that kind of money being spent on that concept when I'm setting up a different axle anyway. For the same or less investment I could just go with a real 44 from hub to hub and be done.
I'm building a 4 banger mileage/expedition/DD/mild trail rig. A thought of budget is in mind at the same time as wanting to get a bit creative in trying to build a better outhouse...
HP30 or 44 for driveline angles and gear strength, nondisconnect for dependability, big brakes to help stop heavier tires, better steering to improve overall driveability, a bit bigger unit bearings than the standard XJ 30 to help with big tire stresses long term, bigger lower balljoints for the same reason.
XJ 44 with different bearing ends for JK brakes and retainers for replaceability and improved stopping power, JK spline count and possibly diff parts for more strength.
AX-15 with a fullsize Jeep 208 and Novak clocking ring for spacing and maybe a little more ground clearance, and much stronger transmission and transfercase with wide chain and gears with a 4 pinion planetary set and factory fixed yoke with a 228/229 front case half so I can twin stick it for 2 low ability...
Basically wanting a Jeep that's better than the factory built, but could have at different points using parts that were available in different Jeeps/Chrysler vehicles over the years...
