rstarch345
- Where ever I can wheel
You might want to consider the manufactures wording and INTENT for the rating of the winch. They might say it is a 9000 lb winch (rolling resistance) in which case that would equate to maybe 5000 lb dead weight.
So 9000 lb is not necessary a 9000 lb winch.
If I were a manufacturer that had high price winches with a low dead weight pull and wanted to move them, I'd call up marketing and ask how? Marketing come back and says, "What's the maximum weight the winch will pull under ideal conditions". Ergo, level and on concrete. So that is what the winch is rated at.
Point is. A rating is a rating by the manufacturers standard. There is NO U.S. Standard for the rating to be sure that all winches are equal.
