austinaubinoe
- Montgomery County, MD
Ok so I just had a very frustration attempt at changing my t case ATF.
-first the funnel and hose I was using to direct the used ATF into the oil pan overflowed. I kinda had a brain fart and thought that the tube was wide enough, should have just held the oil pan up to the tcase :dunce:
Long story short, im pretty much drenched in dirty ATF......
Then I go to fill it up, and end up stripping the fill plug :gonnablow. And this is using only a 10mm Hex Key and a 12" piece of 1/2 inch pipe. ALUMINUM IS TO FINNG SOFT!!!!!!!!!!!!!
To top it all off, it starts to rain :smsoap:.
I have a tap and die set, if I drill and extract the plug, what do i do about metal shavings? Can I buy the different style 231 plugs that you just use a wrench?????
