What weight gear oil for a Dana 30 w/ ARB??
I don't remember it's the 140 ? I used Lucas in my 30 with arb and was good. With my spartan rear did the same but added special slip? Oil cause it made crazy noise which I later found was normal. Sounded very not normal but whatever
You don't need any special oil for the ARB or the spartan locker. Definitely don't need the limited-slip oil as there are no clutches, only teeth.
I do not have lockers yet, but I use Amsoil SevereGear 75-110 both front and rear.
75-140 gl-5, this oil will cover all viscosity ranges from crawling to highway use. No limited slip additive is needed unless your relying on clutchs .
