XJ Eric
- Allegheny National Forest
What the heck is this and where does it go?
I'm working on an 88 MJ with a 4.0. I know very little of the engine. This was found laying in the engine bay and I found a spot on the ignition coil that the connector fit into. Supposedly the truck blows the fuel pump relay and won't run. Well I threw a battery in it and i've got fuel pressure. I even let all the pressure out of the system, turned the key and, YUP, I've got gas pressure again. All's good there. The truck isn't firing up though. Spark is next and since this thing seems to plug into the ignition coil this maybe why it's not firing up?
What is it and where does it bolt up? I can't find any place to bolt it to the engine.
THanks,
Eric
THanks,
Eric
