WB9YZU
- Madison, WI
Here's my .02C.
Having used both synthetic, regular oils in racing applications and having worked on AC engines where synthetics were introduced.
Yes, the synthetic oil generally lubricated better, adheres to surfaces better and more stable (both physical and thermal). As a matter of a fact, I had an engine saved IMO by the use of synthetics when a new oil pumps bypass stuck open durring a WOT 1/4 mile pass. You can run a lower viscosity and still get the same lubricating properties as a higher grade of regular oil, thuse creating less windage loss and better gas milage. My race engines had a set of passes with regular oil (to seat the rings), then from then on, it was synthetic.
General AC engines had a hard time of it when it was introduced.
These engines get outstanding mantance, far more often than your standard car, but,
they burn leaded fuel and generally had been using straight weight oil durring most of their service life. Mobil 1 was introduced and all heck broke loose. People thought, 'hey, more power + longer life' but the opposite happened because the oil cleaned better and broke all the junk loose. Bad news. The oil was refined and most General AC users run a synthetic blend, something like Valvoline "Dura-Blend" but more robust. Still darn expensive
That asside. Changing your oil often (one user said he changes every 1,500mi) will do wonders keeping your engine sludge fee with ANY oil. All oil obsorbs the nasties that go with burning gas, so a regular oil change at 3K is recomended for all oils.
This whole thread comes down to one thing, and one thing only. With a high mileage engine, is it worth throwing $5/qt oil at it? I wouldn't.
The best thing I have found so far to extend the life of my engines is to change your oil, use a good oil (I use 10-30W Valvoline myself), and to change it every 2,000 to 3,000 depending on service it sees. Same thing with your transmission, axles, whatever. You want it to last? Do the mantance - and if you pound on it - do it more often.
,Ron
,Ron
