"An aftermarket Hi Lift jack base. Wider, longer and stronger than the wobbly thing they come with. Something taller that supports the bar and keeps it vertical to the base with or without a load on it but is still easily removable with a couple pins."
"No. Ive got an Off Road base and its not at all what Im talking about. All the off road base does is spread the weight out so it doesnt sink. Im talking about a base that holds the bar vertical so it doesnt have a tendency to wobble or fall to side or front and back with the vehicle supported. A base with a larger footprint than the regular base (similar to the off road base) but that is braced and holds the bar tight enough that it becomes an integral part of the bar so the bar doesnt tend to tip over to the side with a load on it.."
X2
id buy a nice strong base
na i can probably just make my own but for people who cant i bet thos would sell pretty good
Sorry about that. Here it is: you can click on it to make it bigger
The brackets would be one piece and solid all the way through, like 1/4" or 5/16" steel probably :greensmok
Is this possible?
It can be done, but still requires a frame tie-in kit similar to what most aftermarket tow hooks require. Not sure the advantages of having the d-ring mounts higher would make it worth the extra affort of cutting the bumper up to fit the mounts for most people.
Ok I have a good one for you. How about a 3/4" wheel spacer? I cannot find any 5x4.5 wheel spacers that are 3/4" thick except for those stupid insert style ones that dont have the studs.
How about U-bolt plates with a built-in extetended bump stop plate? I have seen something similar on a lift kit, but haven't been able to track JUST that part down.
