fine minus the tires but either way your calculation is incorrect.
no its not
ahh, i think i see the mixup
yes it does output around 200ft lbs at the flywheel
The force applied by the motor shouldn't change depending on tire size unless I am mistaken, but the shock loading (which is far above the force applied by the motor) from wheeling definitely does.
In short, sell that locker and axle on craigslist for as much as you can and get a real axle
Think about holding a ratchet on a bolt and I have a breaker bar on the nut we're both applying force from both sides. Not only will I out power you but that little bolt is going through hell
what exactly is "shock loading"
It's not usually the spinning that breaks a shaft, it's the stopping. It shock loads the shaft when the tire spinning slams into something or gets traction and abruptly is doing 1 mph again.
When the torque load exceeds the axle shaft, it breaks. This can be from too much torque when the tire is bound up, or from spinning then stopping suddenly.
So are you asking us a question or telling us... what?
I'd like to note that I warned you about this axle sucking here: http://www.naxja.org/forum/showthread.php?t=1045933
and again in this thread.
Your own math says it sucks too, and for some reason you're asking if you are right and then telling anyone who disagrees that they're wrong... so I'm a little confused on where you are going with this.
agreed.
if the ratchet is 1 foot long and the breaker bar is 4 feet long, and the bolt isnt turning, then you are applying 1/4" the force that I am applying.
but what does this have to do with what actually breaks the axle?
The heavier your tires are, the more kinetic energy they contain spinning at a given RPM, and therefore the worse the peak impulse torque / shock load is when they abruptly regain traction and stop spinning while the drivetrain is still trying to keep them spinning at the same speed.
Tell ya what... go wheeling with that axle and figure out empirically what causes an axle to break.
I guarantee you it is shock loading in your case, or even constant loading from the locker while turning. You will discover that general terms that aren't well defined will still be very relevant...
I know you like numbers, I do too, but this is pretty intuitively obvious even though I'm not a mechanical engineer versed in statics and dynamics.
we could make a calculator
I think it would be interesting, but there are a whole lot of variables. The condition of your motor, how hard you're hitting the gas pedal, how sharply you shift, what clutch you use, how much play there is in the spider gear teeth from wear, the tread on your tire, the air pressure you're running, temperature, suspension design (leafs have some rotational "give" to them), trail slope, exact trail composition, shaft size and material, how badly the shafts have been abused in the past (are the splines already twisted?), open or locked (and what type of locker), vehicle weight, etc all come into play.im not a mechanical engineer either. i think we can all figure this out. there doesnt seem to be any real explanations of it on the web.
i think its valuable because ultimately, its a cylinder of steel, and it has very well definied characteristics.
if we can figure out the precise reason the axle breaks, we could make a calculator that takes into account many variables, like vehicle weight, engine output, gear ratios, tire speed, tire diameter and weight, and then determine what exact situations are 90% likely to break the axle, and what other situations are safe..i think that would be very interesting dont you
