CHUGLYxj
- Ephrata, PA
akamcbird said:were do ravines come from???
I first saw them on the 60th ann TJ but I know that they were on 06 TJ Sports. Thats where mine came from at least.
Krazors001 said:Ravines replaced the canyons on TJs in 03+ on the sports and saharas. I run a set of ZJ Orvis wheels(same as limited but green inside spokes instead of gold) with a set of spacers. Not a popular swap but I like them. Before these I had a set of cragar 343's.
Ray H said:like was stated, spacers arent needed until you go to the larger tire sizes. With 31X10.50s you will have to adjust your steering stops a little to keep them from rubbing the control arms when fully turned. The steering stops are not a big deal to adjust at all. Using a spacer is either for preference or to fit larger tires.
XJ_ranger said:im planning on swap over to 16" when i get a real front axle and the brakes wont fit in a 15"...
for now i run these -
i like em.
Gojeep said:I run big diameter wheels but dont think you would call me a poser? I am about to run 13" brakes front and rear ( run 12" already ) and the handling is really important to me with all the Outback miles I do loaded up with offroad trailer in tow.
These are 17x8 with 265x70x17 tyres which measure a true 32".
myXJspace said:Have you decided what size tire you want?
I'm contemplating 16's only because the narrow 32" AT tire I want to try is only available in the 235/85/16 size as far as I know.
I didn't have to as these are off a Ford Falcon which are 5 on 4.5"alwaysready said:How did you swap to the 5 on 5 pattern to tun the those wheels??
