Rev Den
- Plainfield, IL
When you say you re-did the U-joints, did you replace them? It almost sounds like you took them apart and re-lubed them, but did not replace them. Any chance you can get it up on stands, apply some brake, and give it some gas? Maybe a brave soul can use a "listening aid" to try to id where the sound is coming from.
Before you all jump on me for suggesting this......
Make sure you use jack stands on a firm level surface
Have room in front of you in case it drops
Have your helper in the truck, you do the listening with a LONG pipe, and a rubber hose to your ear, so if it does fall you are out of the way.
I do not recommend this, but it is an idea.....just be as safe as possable.
Rev
Rev
