Warn industries Made in the USA Tabor Magnum 9K Electric Winch NEW $550 Delivered
RWKHausSupply
A tough winch at a great value
The Tabor 9K by Warn Industries comes with an automatic brake, 100 feet of wire rope, low-profile freespool actuator and a 3-stage planetary geartrain. It’s a whole lot, for a whole little.
· Part Number: 900560
· Rated Line Pull: 9,000 lbs. (4080 kgs) single-line
· Intended Use/Application: Vehicle Recovery/ For trucks and SUV’s
· Motor: Gen II, Series Wound
· Remote Control: Remote switch, 12’ (3.7m) lead
· Geartrain: 3-stage planetary
· Gear Ratio: 216:1
· Clutch (freespooling): Sliding ring gear
· Brake: Automatic direct-drive cone
· Drum Diameter/Length: 2.5”/9.0” (6.4cm/23cm)
· Weight: 89 lbs (36.3 kgs)
· Wire Rope: 100’, 5/16” diameter (30m, 8mm diameter)
· Fairlead: Roller
· Recommended Battery: 650 CCA minimum for winching
· Battery Leads: 2 gauge, 72” (1.83m)
· Finish: Powder coat
Part Number: PN 900560 CE
Mounting Bolt Pattern: 10" X 4.5" (254 mm X 114.3 mm)
Warranty: One year limited warranty
$550 delivered to the lower USA.
Robert
RWK Haus Supply
