I need a axle shaft for a tire carrier i'm building. Has to have the studs and at least 12" of shaft. It could be from a d35, 8.25, d44, as long as it will fit my stock rims.
well if you make is sandwich slightly on soem adjasent tube it works great! you just use the hub bolds to secure the unitbearing to the structure and then bolt on the tire. gives you a spare unit bearing also in case soemthing really bad happends.
One thing though, you Have to get a 2wd outer stub/bearing preload axle. that way the bearing doesnt come apart over time without any preload on it.
