montanaman
- Western Montana
Hi ... Looking for an external cylinder Bellhousing from an AX15 ... it is found on years '94+. I'm converting my '91 to external cylinder. Do you have a blown AX15 with External slave cylinder?
Here is what I need:
- Bellhousing ... here is a pic of internal vs. external slave bellhousings:
http://i47.photobucket.com/albums/f1...aveswap008.jpg Internal on left, external on right. I need the external.
- Front Bearing Retainer:
http://i47.photobucket.com/albums/f1...aveswap002.jpg I need the kind on the right, with the big tube.
- Clutch fork
- Little plastic ball that holds clutch fork to bellhousing
- Little clip that holds clutch fork to the plastic ball
- Throwout bearing
Here is a pic of the above parts:
http://i47.photobucket.com/albums/f1...aveswap013.jpg
-External slave cylinder
I can get by without the throwout bearing and slave cyl if necessary.
External slave AX15s are generally found on '94+ XJs and Wranglers.
Let me know what you think.
Thanks
- Clutch fork
- Throwout bearing
Thanks
