Tally_XJ
- Tallahassee, Florida
1989 Cherokee 4x4
4.0 liter
AW4 tranny
My CPS (crank position) went out on me again. Seems it happens once a year.
Usual symptoms. Running great then all of a sudden shuts off and wont crank again. No spark, no injector pulse. Let it sit a while, cranked up and then shut right back off ater a minute. Same no spark and no injector pulse.
Replaced the sensor. Jeep fired right up and idles perfectly and doesnt shut off.
However, now it will not take the throttle. Anything off idle it stutters, bucks, spits and busts up really bad. I cant get it to throttle up above 1500 RPM and even then its busting up bad. It returns to a smooth as a sewing machine idle and never shuts off, just wont take the throttle at all.
No smoke out the pipe. No cat so its not exhaust related. Has never done this before.
Had it towed to my work and there I did the following:
- checked fuel pressure (steady at 38psi)
- replaced spark plugs (Champion copper plus)
- Checked plug wires
- Checked connections at CPS and TPS
- Checked MAP connections and vacuum lines
4.0 liter
AW4 tranny
