Mine is a RENIX as well. I had a LOT of leaks and a bad case of blowby. I cut out all of the plastic vac lines (one at a time) and replaced them with correct size tubing. You can see where my group of lines used to connect in the lower right of the pic. I removed the mount as well. Works like a champ. Any questions let me know.
Yes it is brake line. Just make sure you get as close to the inside diam as your stock line. Since this pic I have replaced the front breather tube (blue) connection to the valve cover. I used a chrome breather from auto zone and connected my line (blue) to it then to the airbox. If that makes any sense.
