5-90
- Hammerspace
Pull the access cover at the lower front of the bellhousing and look at the flexplate. If you see a lot of radial "splatter" of oil all around (you can turn the engine easily with a 3/4" socket on a breaker bar or long-handled ratchet,) then I'd look at the rear main. If your flexplate is clean, start thinking about the valve cover.
Given the overall experience with valve cover gaskets, tho, I'd think about replacing the thing anyhow. I really should get that write-up done for the FAQ section - I didn't even volunteer that one!
5-90
5-90
