badazzcherokee3
- California
Is this what you where thinking of because this is what I was leaning towards
who made that?badazzcherokee3 said:Is this what you where thinking of because this is what I was leaning towards
badazzcherokee3 said:ROC DOG Fabrication makes them
badazzcherokee3 said:Yup but if you do decide to go with them keep me updated I would like to see them on a jeep first
badazzcherokee3 said:This sounds like it is only for one side of the unibody frame. But I could very well be wrong I'll have to call and find out.
ROC DOG Fabrication has designed and developed these unibody stabilizers for use on Jeep Cherokee XJs after careful design development for their own Jeep Speed vehicle. The entire kit includes stiffeners for the front and rear of Jeep XJs as well as a special plate designed reinforce the unibody behind the steering box. The entire set is CNC plasma cut from 3/16ths steel. There is some custom bending required to obtain an accurate fit for your Cherokee XJ. These parts provide their best support when they are completely welded to the unibody rails.
The front rail stiffeners fit behind the wheel along unibody rails. Circular openings provide weight reduction as well as welding points for secure mounting. Providing a 2 piece front stiffener allows for custom applications and adjustments.
The rear rail stiffeners mount directly behind the rear wheels and like the front rail stiffeners, circular openings provide weight reduction as well as welding anchor points.
aparke4 said:for over 200 it better be for both sides! it is just 3/16 though
JeepFreak21 said:I think 3/16" is pretty widely accepted. Some folks even want to go thinner to save weight.
Billy
