jeannies_driver
- Drumore, Pennsylvania
Okay, let's try this once again :helpme:
I started this last year in hopes of making KOH 2012 but just as I started work dropped off and I was left staring at it in the garage.
My goal is to qualify in the RCQ and finish installing the bling Spyder 9's sitting in the corner. Not enough time or money to fit them in at this point.
Instead, I'm polishing turds and praying they hold up for one race....
I don't think it could be any more basic and " stock " than this build. If you're looking for awesome tech, dimple die's, roll bending and "pretty" welds it's NOT going to be in here !
Jeep has absolutely been stripped of everything, finally.
Clayton Offroad sent down some parts to help with the build. This is part of their Pro Series 3 link kit
3 link axle bridge installed
3 link cross member bolted up and final welded in place. If it moves, I'm gonna need another jeep afterwards.
Clayton Offroad Pro Series 3 link installed. I also cut off the lower control arm mount on the axle as well as the shock mounts. Mounted up some Ruff Stuff lower link mounts to hold everything in place.
Rear springs had to be ordered and are on their way.
Shocks from Profender will be ordered tomorrow most likely. 2.0" x 10" remote reservoir should help soften up the ride some.
AtoZ Fab is supplying the tube for my roll cage as well, I just need to go pick it up.
If anyone would like to help build, donate parts/sponsor, stand around and make fun You're more than welcome to come over.
( Except Andy ) :wave:
