yossarian19
- Grass Valley, CA
Well, it finally happened: I started getting noise from the front right U-joint. It's got play and it's got to get replaced. First time I'll have done the job, so...
It looks like removing the caliper, axle nut (centered in rotor), rotor & the 3 hub to knuckle bolts will let me pull the whole axle out. I then press the bearing caps apart in a vice and knock it off the shaft, throwing a new U joint in before re assembling.
The rig spent 13 years of its life in Utah. The axle is rusty.
What is likely to go wrong? Am I better off throwing a JY shaft in there and calling it a day? The new U-joint is 15 bucks but with my time involved I'm not sure it is worth messing with...
What say you, guys?
What say you, guys?
